Pudgie_japanese's avatar
Jul 14, 2017
Nighthawk R8000 won't let me connect more than one device
Trying to set up new Nighthawk X6 AC3200 Tri-Band R8000 wifi router and it won't let me connect to more than one device at a time. I am using Apple devices and an XBox. Any ideas?
  • JamesGL's avatar
    JamesGL
    Jul 19, 2017
    Hi Pudgie_japanese,
    You may try to reset the router to factory default.
