cooncats
Aug 14, 2024Aspirant
Nighthawk R8000 X6 AC3200 flashed to DDWRT
Got this router to use with my VPN. They require it to be flashed to DDWRT. I actually found a late version of DDWRT that works, July 27, 2024. My VPN claimed they supported this router but their ...
- Aug 14, 2024
DDWRT can take different ways to recover. Its why when its been flashed with aftermarket firmware, it has to go through that forum to help fix it. the procedures we give might cause issues.
so go to the DDWRT forums for help. They might have even already went over recovering from a bricked procedure.
cooncats
I need to reflash direct, not through the DDWRT interface which is inaccessible. Can you help me with this?
Can it be accessed from a USB port?
Aug 14, 2024Guru - Experienced User
