cooncats
Aug 14, 2024Aspirant
Nighthawk R8000 X6 AC3200 flashed to DDWRT
Got this router to use with my VPN. They require it to be flashed to DDWRT. I actually found a late version of DDWRT that works, July 27, 2024. My VPN claimed they supported this router but their ...
- Aug 14, 2024
DDWRT can take different ways to recover. Its why when its been flashed with aftermarket firmware, it has to go through that forum to help fix it. the procedures we give might cause issues.
so go to the DDWRT forums for help. They might have even already went over recovering from a bricked procedure.
cooncats
I am told over there it cannot be fixed via DDWRT. This situation is very similar to some threads here where some versions of Factory firmware bricked R800's. This is basically a brick situation caused by a bad build of DDWRT, not repairable through the DDWRT interface.
So to repeat, is there any way to flash this router back to Factory using something like that TFTP procedure in the 2020 thread? If that still works is there an updated guide for it for Windows 11? I'll take my chances with any direct method that might work as this router is basically bricked any way.
Thanks.
Aug 14, 2024Guru - Experienced User
You can try this method that forced the R8000Pto upgrade when it was locked. Maybe it'll help. Or try tftp or nmrp flash
Solved: R8000P V1.4.1.50 Update workaround - NETGEAR Communities
