Routermania17
Aug 21, 2017Aspirant
Nighthawk R8000 x6 New firmware issue V1.0.3.54_1.1.37
Hi everybody, I just updated to the last versionof firmware my router but i noticed that with the 5 GHZ band devices keep disconnecting.. Anybody has this issue ? Thanks.
- Nov 30, 2017
Hi Routermania17,
Here is the latest firmware.
https://kb.netgear.com/000052298/R8000-Firmware-Version-1-0-4-4
Irish3211
Nov 06, 2017Aspirant
Hello All,
Here is my issue, I have the latest firmware update and since that update I have had a terrible time staying connected or getting any of the download or upload speeds I am paying for. I had an Xfinity guy come out and dissconnect the router and test the modem and am getting on avearge download speeds of 250mbps and uploads of around 11 - 12mbps. Once we connect the router it drops to 40mbps - 60mbps,
I have reset the router, I have disconnected everything and redid set up and still the same issue. I have talked a a few trusted colleauges and they mentioned the latest update Version:1.0.3.54_1.1.37 is causing these issues and I need to rollback to the previous firware release.
Any advice or reccomendations would be very helpful. Thanks
Brian
- JamesGLNov 22, 2017NETGEAR Employee Retired
Hi Irish3211,
Can you post the statistics of the WAN port.https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
- Routermania17Nov 28, 2017Aspirant
With the latest firmare V1.0.4.2_1.1.41... I got the same issue of disconnecting from the 5GHZ band saying that the password is not correct even if it retype it correctly..
- JamesGLNov 30, 2017NETGEAR Employee Retired
Hi Routermania17,
