Routermania17
Aug 21, 2017Aspirant
Nighthawk R8000 x6 New firmware issue V1.0.3.54_1.1.37
Hi everybody, I just updated to the last versionof firmware my router but i noticed that with the 5 GHZ band devices keep disconnecting.. Anybody has this issue ? Thanks.
- Nov 30, 2017
Hi Routermania17,
Here is the latest firmware.
https://kb.netgear.com/000052298/R8000-Firmware-Version-1-0-4-4
Irish3211
Nov 06, 2017Aspirant
Hello All,
Here is my issue, I have the latest firmware update and since that update I have had a terrible time staying connected or getting any of the download or upload speeds I am paying for. I had an Xfinity guy come out and dissconnect the router and test the modem and am getting on avearge download speeds of 250mbps and uploads of around 11 - 12mbps. Once we connect the router it drops to 40mbps - 60mbps,
I have reset the router, I have disconnected everything and redid set up and still the same issue. I have talked a a few trusted colleauges and they mentioned the latest update Version:1.0.3.54_1.1.37 is causing these issues and I need to rollback to the previous firware release.
Any advice or reccomendations would be very helpful. Thanks
Brian
JamesGL
Nov 22, 2017NETGEAR Employee Retired
Hi Irish3211,
Can you post the statistics of the WAN port.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
- Routermania17Nov 28, 2017Aspirant
With the latest firmare V1.0.4.2_1.1.41... I got the same issue of disconnecting from the 5GHZ band saying that the password is not correct even if it retype it correctly..
- JamesGLNov 30, 2017NETGEAR Employee Retired
Hi Routermania17,
- JamesGLDec 04, 2017NETGEAR Employee Retired
Hi Routermania17,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
