DSing
Jan 12, 2021Guide
Nighthawk R8000 X6 Slow Wifi speed
Hi All As above, I have a 900m/b connection but only getting around 500 down, but upload speed is fine at 120m/b. I am with BT and they say I am set at 980 download, but they can only check if I...
Jan 12, 2021Guru - Experienced User
Which sky hub/bt hub do you have?
Many have their own integrated router and it can cause a double nat.
DSing
Jan 12, 2021Guide
I don’t use any other sky hub or BT hub for internet. The sky box I refer to is for TV my sky q box?
I don’t have my BT Hub plugged in, hence why BT can’t do a complete check in my home only the line.
- plemansJan 12, 2021Guru - Experienced User
Something is supplying the R8000 with an internet connection.
What is the r8000 connected to thats acting as a gateway?
