DSing
Jan 12, 2021Guide
Nighthawk R8000 X6 Slow Wifi speed
Hi All As above, I have a 900m/b connection but only getting around 500 down, but upload speed is fine at 120m/b. I am with BT and they say I am set at 980 download, but they can only check if I...
Jan 12, 2021Guru - Experienced User
test with a hardwired in pc/laptop
try different sites as well. when you get >500mbps, some test sites have issues saturating the line.
DSing
Jan 12, 2021Guide
Cheers my speed has dropped to about 150 meg again tonight all very weird! Nothings changed from my side still set up same
