tonberry56
Sep 09, 2023Follower
nighthawk R8000P not updating firmware through app and unable to reach site on desktop
hello all I am having trouble updating my nighthawk router to the latest firmware update. when i try to update it through the nighthawk app it states it is unable to at the time even after hitting th...
- Sep 09, 2023
Factory reset and setup from scratch. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
Sep 09, 2023Guru - Experienced User
