stedgar
Jul 17, 2022Aspirant
Nighthawk R8000P NTP Server
I have a Netgear Nighthawk R8000P Router with Firmware Version V1.4.3.88_1.3.50. I am unable to adjust the NTP settings. Keeps defaulting to International Date Line West. I have pinged time...
Jul 17, 2022Guru - Experienced User
What browswer are you using to log into the routers web page? Same thing happen with MS Edge or Firefox?
- stedgarJul 18, 2022Aspirant
Hello. I am using both Edge and Chrome. Neither one will permit me to change the NTP setting or server location.
I am using Frontier Fiber and their modem is locked in a box in the garage. Please note that I have never had a problem with this before. I have even unplugged their modem to reset it.
Long story short, I was experiencing lagging delays and slow internet speeds. So I went ahead and did a complete reset of my Netgear router and was able to set everything up like I had before with the exception of the NTP issue. That is the only issue now is to set the NTP.
Thank you.
