TwoTabs
Nov 07, 2021Apprentice
Nighthawk R8000P Port Problem
For the last few days i have been trying to play Battlefield 4. It keeps telling me that i need to open port 3659 UDP on my router. I have opened the port and i have opened the port on windows firewa...
TwoTabs
Nov 08, 2021Apprentice
I am on the latest firmware verzion of that router. i also noticed that every once in awhile when i reboot my router that its not picking up the public IP from the modem all the time. I just upgraded to Gig a couple months ago, i wonder if the modem is causing this problem. I am using Spectrum. I will have to check to see the exact modem model number
Nov 08, 2021Guru - Experienced User
An actual firmware version helps more than "the latest".
Sometimes people aren't actually on the latest, or the version they're on is known for issues. Its why we ask for an actual number
- TwoTabsNov 08, 2021Apprentice
I will check when i get home from the office later. Ill get the firmware version and the modem model number
Firmware version is 1.4.2.84_1.3.42
My Modem is attched in the photos. It looks like it is a docsis 3.1 model EU2251.My ISP is Spectrum and im on the gig plan
- plemansNov 09, 2021Guru - Experienced User
try installing version 1.4.1.68 of the firmware to the router. Then do a factory reset and reinstall on it. And disable auto-updates.
Try that and see if it helps. The .84 version has had dns issues and maybe its causing some of your port issues.
