longobongo's avatar
longobongo
Nighthawk R8000p router keeps trying to update
I received an update notice through the Nighthawk app a proceeded to download the new firmware. After doing this I received another message saying that I need to update again. Again I downloaded the n...
  • plemans's avatar
    Jan 26, 2021
    What firmware version are you on?
    One thing, I'd recommend against updating using the app or over wireless. when we see corrupt firmware versions, its usually when done via the app or wireless. I'd do it over a hardwired connection for best results.
    When the speeds slowed down, did you ever try a factory reset and reinstall? if there's issues after changing firmwares, thats one of the first things we recommend.
