Voltz1228
Jul 08, 2021Guide
Nighthawk R8000P WAN aggregation error
I am trying to setup the WAN aggregation as my internet speed is over 1 gigabit. My modem is an Arris SB8200, I have already enabled the aggregation settings on that device. Whenever I try to enable ...
- Jul 08, 2021
what version of firmware are you on?
Looks like it was added in version 1.4.1.42
did you enable wan port aggregation on the SB8200?
Enable it on both devices. power them both off, then turn on the modem, give it a couple minutes, then power on the r8000P
Jul 08, 2021Guru - Experienced User
From what I see the R8000P only support lan link aggregation and not WAN port aggregation.
- Voltz1228Jul 08, 2021Guide
That is what I originally thought the issue was as well, until I found this page on the netgear website that specifically mentions the R8000P as being able to do it. Plus the fact that it shows as an option when I go the the routerlogin.net page.
- plemansJul 08, 2021Guru - Experienced User
- Voltz1228Jul 08, 2021GuideFirmware is 1.4.1.68, and yes I have it enabled on the SB8200. I will try that power order when I get home from work. However, previously the error popped up as soon as I applied the configuration before I could even connect the cables, as if it failed to apply the configuration itself. Is it normal for it to say that before everything is finished getting connected?
