Voltz1228
Jul 08, 2021Guide
Nighthawk R8000P WAN aggregation error
I am trying to setup the WAN aggregation as my internet speed is over 1 gigabit. My modem is an Arris SB8200, I have already enabled the aggregation settings on that device. Whenever I try to enable ...
- Jul 08, 2021
what version of firmware are you on?
Looks like it was added in version 1.4.1.42
did you enable wan port aggregation on the SB8200?
Enable it on both devices. power them both off, then turn on the modem, give it a couple minutes, then power on the r8000P
Jul 09, 2021Guru - Experienced User
but the guide for it shows the wan port and lan port 4
https://kb.netgear.com/000061095/How-do-I-set-up-Ethernet-port-aggregation-between-my-NETGEAR-Nighthawk-Multi-gig-Speed-Cable-Modem-and-my-NETGEAR-Nighthawk-router
Voltz1228
Jul 11, 2021Guide
I’ve managed to fix it using the boot order you suggested. For anyone that finds this in the future, I also replaced the cables I was using with 2 identical brand and length cat 6 cables, and the ports that should be used are the WAN Internet port and Ethernet port 4. Thank you for your help.
- plemansJul 11, 2021Guru - Experienced User
Glad to hear you got it working!
If you mark the solution as solved it might help the next person
