PapaWoof
Jan 09, 2022Star
Nighthawk R8000p Wifi dropping - Any updates?
Still having lots of wifi drops on our R8000P router. I have tried everything and it will be find and just start totally dropping. Anyone have any new ideas on how to fix? Netgear when are you going ...
TraceyHart
Jan 11, 2022Initiate
Also facing the same issue at my end. Wifi keeps disconnecting but it happens only on mobile devices not on laptops, I don't know what is causing the issue.
- FURRYe38Jan 12, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
