PapaWoof
Jan 09, 2022Star
Nighthawk R8000p Wifi dropping - Any updates?
Still having lots of wifi drops on our R8000P router. I have tried everything and it will be find and just start totally dropping. Anyone have any new ideas on how to fix? Netgear when are you going ...
PapaWoof
Jan 14, 2022Star
Well the full reset and reload and everything else was fine for about 48 hours then it started dropping again on the AC4000/R8000P. I tried all the suggested settings and no luck.
I even swapped 2 different Netgear A6100, Netgear A7000 and Linksys AC6700 usb wifi's and no luck all of them would go a bit and then start dropping. I installed the Netgear Genie and it was detecting quite a few drops. I uninstalled and reinstalled everything.
So back to my old Netgear DGND4000 Router and my Linksys usb wifi and it's been totally stable now.
So frustrating!!!
- FURRYe38Jan 14, 2022Guru - Experienced User
- PapaWoofJan 14, 2022Star
No one that is netgear or same channel, have checked that out
My DGND4000 is the same exact settings and no issues at all
- DexterJBJan 18, 2022NETGEAR Moderator
Hi PapaWoof, we recommend contacting our support team for further troubleshooting and isolation. You can always reach our support team via the link below if you need any technical assistance with your NETGEAR device.
https://www.netgear.com/home/contact-us/default.aspx
You can also call the number below.
1-888-NETGEAR (1-888-6384327)
Dexter
