PapaWoof
Jan 09, 2022Star
Nighthawk R8000p Wifi dropping - Any updates?
Still having lots of wifi drops on our R8000P router. I have tried everything and it will be find and just start totally dropping. Anyone have any new ideas on how to fix? Netgear when are you going ...
PapaWoof
Jan 14, 2022Star
No one that is netgear or same channel, have checked that out
My DGND4000 is the same exact settings and no issues at all
DexterJB
Jan 18, 2022NETGEAR Moderator
Hi PapaWoof, we recommend contacting our support team for further troubleshooting and isolation. You can always reach our support team via the link below if you need any technical assistance with your NETGEAR device.
https://www.netgear.com/home/contact-us/default.aspx
You can also call the number below.
1-888-NETGEAR (1-888-6384327)
Dexter
