Lakeman46
Apr 15, 2024Tutor
Nighthawk R8000P won't accept new devices
My router isn't accepting any new devices. All older devices that I have on it are working fine. My firmware is up to date. My WPS is on, I've reboot the router and powered down the modem. All old de...
- Apr 15, 2024Firmware is 1.1.4.94
Not sure about gateway
15 devices
Not using Smart connect
I was trying to connect wyze V3 cameras on 2.4 gig.
Apr 15, 2024Guru - Experienced User
What firmware version are you on? The latest doesn't help
what modem/gateway is it connected to?
How many devices are connected?
Are you using smart connect?
Lakeman46
Apr 15, 2024Tutor
15 devices
15 devices
- plemansApr 15, 2024Guru - Experienced User
Lakeman46 wrote:
Firmware is 1.1.4.94----Maybe you mean 1.4.4.94? If not, you are outdated by quite a ways.
Not sure about gateway----Thats important to check. A double nat can cause issues.
15 devices---should still be able to add devices.
I was trying to connect wyze V3 cameras on 2.4 gig.Is the wyze giving you the errors? did you contact th em?- Lakeman46Apr 15, 2024TutorIt is 1.4.4.94 sorry
I don't know how to check the gateway. The cable connects from the modem to the router.
I tried 3 wyze v3 cameras and all said the same thing can't connect to wifi.
I've tried to connect other cell phone to my wifi calling, says the same thing can't connect. No new device will connect.- plemansApr 15, 2024Guru - Experienced User
What modem is that? that's the key. It should have a label on it.
do you have ipv6 enabled?
Is the phone on 2.4ghz during setup of the camera's?
