Lakeman46
Apr 15, 2024Tutor
Nighthawk R8000P won't accept new devices
My router isn't accepting any new devices. All older devices that I have on it are working fine. My firmware is up to date. My WPS is on, I've reboot the router and powered down the modem. All old de...
- Apr 15, 2024Firmware is 1.1.4.94
Not sure about gateway
15 devices
Not using Smart connect
I was trying to connect wyze V3 cameras on 2.4 gig.
Apr 15, 2024Guru - Experienced User
Lakeman46 wrote:
Firmware is 1.1.4.94----Maybe you mean 1.4.4.94? If not, you are outdated by quite a ways.
Not sure about gateway----Thats important to check. A double nat can cause issues.
15 devices---should still be able to add devices.
I was trying to connect wyze V3 cameras on 2.4 gig.Is the wyze giving you the errors? did you contact th em?
Lakeman46
Apr 15, 2024Tutor
It is 1.4.4.94 sorry
I don't know how to check the gateway. The cable connects from the modem to the router.
I tried 3 wyze v3 cameras and all said the same thing can't connect to wifi.
I've tried to connect other cell phone to my wifi calling, says the same thing can't connect. No new device will connect.
- plemansApr 15, 2024Guru - Experienced User
What modem is that? that's the key. It should have a label on it.
do you have ipv6 enabled?
Is the phone on 2.4ghz during setup of the camera's?
- Lakeman46Apr 15, 2024TutorThe modem is a Calix 836GE RGS
How do I check if the if the ipv6 is enabled.
I'll probably have to check it on my netgear app on my PC.
The phone is on 2.4gig when connecting cameras.
I have to run some errands and won't be back tell later this afternoon.
Thank you for helping- plemansApr 15, 2024Guru - Experienced User
From what I could find, that calix is a modem/router combo device. It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
