MyGHawk
Nov 10, 2021Follower
Nighthawk R8000P X6S Remote Management option missing
I do not have the link option of Remote Management on my router. I went into Advanced -- > Advanced Setup and there should be a link to Remote Management but it's not there nor anywhere else on the tabs. How do I get this installed?
Firmware Version V1.4.2.84_1.3.42
NG seems to have removed Remote Management. You may see Web Services management in it's place and form there, you'll need to use the NightHawk app on a mobile device to connect when you are remote from the local network.
1 Reply
