LeadPipe
Aug 11, 2023Aspirant
Nighthawk R8000Pturn on IPV6
Hi I have a P8000 and I’m trying to turn on IPv6 to run an Xbox series x. Is there a way to turn this on? The version I have is V1.4.4.94. My ISP is Hotwire communications. I have very little technic...
- Aug 16, 2023
Tech was here made a bunch of calls and determined IPV6 isn’t available yet. “It’s something we’re working on”. It’s 50/50 if it’s actually not turned on or they just wanted to get rid of me. But anyway thanks everyone for the help.
michaelkenward
Aug 12, 2023Guru - Experienced User
LeadPipe
Aug 12, 2023Aspirant
Do you know how I would get to the log in window?
Thanks!
- LeadPipeAug 12, 2023Aspirant
Also the Xbox has a way to test your NAT type. It will say, open, moderate, strict or double NAT. So the ONT may already have bridge mode enabled because mine is open, it was strict until I opened some ports. I may just need to go in and enable IPV6.
- LeadPipeAug 14, 2023Aspirant
Thanks for the help. I tried logging in and it gave me a network change error and shut me out of tv for a while. The internet came back after a few minutes. I’m going to call them and have them do it. Do you think there is any negatives to getting a switch and bypassing the router (just for the Xbox)? Thanks again for the help.
- michaelkenwardAug 14, 2023Guru - Experienced User
It won't work.
Without your router, The Xbox won't know where to go.
The switch would be connected to the ONT. since the ONT only has one working port my plan was, instead of connecting the router to that port I would run a switch and connect the router and the Xbox to the switch. I was able to connect the Xbox directly to the ONT and it worked. Just want to give you a clear picture of what I’m doing.. This won’t work?
Thanks - michaelkenwardAug 14, 2023Guru - Experienced User
Okay thanks!
- KitsapAug 15, 2023Master
With the X box connected directly to the ONT, did it have an IPv6 address?
- LeadPipeAug 15, 2023Aspirant
It did not.
Please provide an update after you have had your ISP make changes to the settings in your ONT.
Will do, they said the ONT is configured for both and the determination is made the router but they are sending a tech here tomorrow. I’m going to try hooking the Xbox back up to the ONT and reset everything and see if anything changes.
thanks
- LeadPipeAug 16, 2023Aspirant
- KitsapAug 16, 2023Master
LeadPipe wrote:Tech was here made a bunch of calls and determined IPV6 isn’t available yet. “It’s something we’re working on”. It’s 50/50 if it’s actually not turned on or they just wanted to get rid of me. But anyway thanks everyone for the help.
Appreciate your providing feedback. At least for the moment, now you know.
I would feel more confident if I knew 100% that my router supports IPV6.
- michaelkenwardAug 16, 2023Guru - Experienced User
You aren't the first, and won;lt be the last, customer to be fed dud information by their ISP's "tech support". Pity they wasted your time when you first asked if they support IPv6.
