LeadPipe
Aug 11, 2023Aspirant
Nighthawk R8000Pturn on IPV6
Hi I have a P8000 and I’m trying to turn on IPv6 to run an Xbox series x. Is there a way to turn this on? The version I have is V1.4.4.94. My ISP is Hotwire communications. I have very little technic...
- Aug 16, 2023
Tech was here made a bunch of calls and determined IPV6 isn’t available yet. “It’s something we’re working on”. It’s 50/50 if it’s actually not turned on or they just wanted to get rid of me. But anyway thanks everyone for the help.
LeadPipe
Aug 12, 2023Aspirant
Do you know how I would get to the log in window?
Thanks!
LeadPipe
Also the Xbox has a way to test your NAT type. It will say, open, moderate, strict or double NAT. So the ONT may already have bridge mode enabled because mine is open, it was strict until I opened some ports. I may just need to go in and enable IPV6.
