LeadPipe
Aug 11, 2023Aspirant
Nighthawk R8000Pturn on IPV6
Hi I have a P8000 and I’m trying to turn on IPv6 to run an Xbox series x. Is there a way to turn this on? The version I have is V1.4.4.94. My ISP is Hotwire communications. I have very little technic...
- Aug 16, 2023
Tech was here made a bunch of calls and determined IPV6 isn’t available yet. “It’s something we’re working on”. It’s 50/50 if it’s actually not turned on or they just wanted to get rid of me. But anyway thanks everyone for the help.
LeadPipe
Aug 15, 2023Aspirant
Will do, they said the ONT is configured for both and the determination is made the router but they are sending a tech here tomorrow. I’m going to try hooking the Xbox back up to the ONT and reset everything and see if anything changes.
thanks
LeadPipe
Aug 16, 2023Aspirant
- KitsapAug 16, 2023Master
LeadPipe wrote:Tech was here made a bunch of calls and determined IPV6 isn’t available yet. “It’s something we’re working on”. It’s 50/50 if it’s actually not turned on or they just wanted to get rid of me. But anyway thanks everyone for the help.
Appreciate your providing feedback. At least for the moment, now you know.
- LeadPipeAug 16, 2023Aspirant
I would feel more confident if I knew 100% that my router supports IPV6.
- michaelkenwardAug 16, 2023Guru - Experienced User
You aren't the first, and won;lt be the last, customer to be fed dud information by their ISP's "tech support". Pity they wasted your time when you first asked if they support IPv6.
