shadowdiver's avatar
shadowdiver
Nighthawk R8500 - Cannot rename device
I have roughly 40 devices attached to my router.  I have been able to rename all my attached devices but starting at about device 38 or so, I have been unable to rename new devices.  I can rename dev...
  • shadowdiver's avatar
    shadowdiver
    Feb 08, 2020
    I installed the app and it let me change the name but the names kept resetting.  I finally gave up and factory reset the router.  Took a couple of hours to reset all the devices on the network but the renaming issues seems to be resolved.
