Evicmar
Mar 10, 2021Guide
Nighthawk R8500 guest network seeing devices when disabled
In the guest network section, "Allow guests to see each other and access my local network" is not selected and my work laptop can see devices on my home network. I'm on firmwware V1.0.2.144. I've tri...
antinode
Mar 10, 2021Guru
> I'm connecting to the wifi network through my laptop's gui. [...]
> Your (unspecified) "my work laptop" is connected to the R8500 using a
> "Guest Network" SSID?
See the difference?
Evicmar
Mar 10, 2021Guide
Are you not seeing that the make, model, etc of the laptop make no difference in this situation? I just got a linux laptop and ran a nmap scan of ports 1-1000 against the IP range I set up and nothing is being blocked. Is this a software bug for the router or is it the illusion of security?
- EvicmarMar 10, 2021Guide
I went one step further. I ran the same nmap on an intel atom box I have that has a RJ45 connection to my router and did a tee of the output to a flat file. I did the same from the linux laptop on the guest network and then scp'd the file from the intel atom box to my laptop while on the disabled access guest network. I then ran a diff against the output files. The diff came out with nothing different in the files.
- antinodeMar 10, 2021Guru
> Are you not seeing [...]
No. What I'm not seeing is your clear statement that you're using a
guest-network SSID for anything. With my weak psychic powers, I can't
see what you did, only what you wrote. And that's not clear enough.Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Set Up a Guest WiFi Network". Note that new/different SSIDs are
involved. "Wireless" and "Guest" are spelled differently for a reason."my work laptop" tells me nothing about how that device is connected
to anything. Perhaps you're doing everything correctly, and the
firmware on your R8500 is garbage. But, from your description, I can't
tell.- EvicmarMar 18, 2021Guide
I work as a Systems Administrator. The devices are connected correctly. I have gone through the documentation and the guest network is setup correctly. I have also tried downloading the firmware update file 3 different times now and forcing an update of the firmware through the administration page using a different downloaded file each time. After every time, I can see everything from the guest network though nmap.
