rob_dav
Jan 21, 2022Tutor
Nighthawk r8500 replacement
I have a r8500 router that has started to drop out. I've had the unit since about 2016. I've had no problems till now. Im guessing it is about to die. Does anyone have a recommendation on a replacemen...
rob_dav
Jan 22, 2022Tutor
Thank you for your input. I'll give it a try.
I have already done a factory reset and updated the firmware to no avail.
The unit is at least 6 years old and this problem has only started in the last month or so. Hence why I suspect the unit is on its way out and the issue is a hardware issue.
Jan 23, 2022Guru - Experienced User
Updating the firmware isn't always the best option. there's been quite a run lately on "the latest firmware" causing issues on devices.
Try downgrading a version or 2 and see if the performance picks back up. You might need to factory reset after downgrading. (and disable auto-updates)
- rob_davJan 24, 2022TutorThe router was dropping out before the firmware was updated or factory reset.
- plemansJan 24, 2022Guru - Experienced User
up to you on trying other firmwars.
If you're looking for better than what you had, you gotta go to a pretty decent AX router to get better than the R8500.
The RAX78 is the base tri-band AX router. I've seen it on "renewed" on amazon for pretty reasonable.
Are you looking for triband or moving back to dual band?
Or are you looking at moving to a mesh system?
- rob_davJan 24, 2022TutorI was looking for the same or better.
I bit the bullet and picked up a new RAX 200.
As the old unit was 6 years old and had no issues untill about a month ago.
