rob_dav
Jan 21, 2022Tutor
Nighthawk r8500 replacement
I have a r8500 router that has started to drop out. I've had the unit since about 2016. I've had no problems till now. Im guessing it is about to die. Does anyone have a recommendation on a replacemen...
rob_dav
Jan 24, 2022Tutor
I was looking for the same or better.
I bit the bullet and picked up a new RAX 200.
As the old unit was 6 years old and had no issues untill about a month ago.
Jan 24, 2022Guru - Experienced User
that'll be a step up!
Went full max it out with the RAX200.
I have one and its a beast. I do a lot of data moving and I'm not even close to maxing its potential.
I hope it works well for you!
