CarlosKC
Jun 11, 2016Aspirant
Nighthawk R8500, USB 3.0 Flash Drive Not Recognized in USB 3.0 Port, only 2.0 Port
My Nighthawk R8500 Router with latest firmware, V1.0.2.54_1.0.56, will not recognize my SanDisk Ultra Fit 128 GB USB 3.0 Flash Drive when plugged into the router's USB 3.0 Port. The Ultra Fit is form...
- Jun 23, 2016
Tech support followed up with me. Installing a firmware update, V1.0.2.64_1.0.62, which became available shortly after my post, solved the issue. - Carlos
krazekiote
Jun 12, 2016Initiate
Having the same problems myself. Have not figured it out either. I'm having problems on other devices identifing my 3.0USB 128GB drives. I think there are firmware limitations on identifing these drives.
ElaineM
Jun 13, 2016NETGEAR Employee Retired
Let me inquire this to our engineering team.
- pj1000Jun 26, 2016Aspirant
Recent firmware upgrade didn't solve my problem of recognizing Samsung 128GB EVO Select Micro SDXC Memory Card, 80MB/s (MB-ME128DA/AM). The 15 GB Sandisk I had installed was working fine. I used the same USB carrier. The larger MicroSD is just not being read. Any ideas here?
