Jbienz
Feb 09, 2022Guide
Nighthawk r9000 - bridge/Access point
I need some sort of combination of bridge mode and wireless access point and could use some suggestions. I have Verizon Fios and need to keep their router as my main router. That router is located ...
Feb 09, 2022Guru - Experienced User
got coax ran through the home?
A set of moca adapters (ethernet over coax) would allow you to connect the fios router and the r9000. Then you'd just run t he r9000 in AP mode.
Jbienz
Feb 09, 2022Guide
Thank you. Great question. I’ll dig around and see if I can find any coax on the third floor.
For the sake of this discussion though, let’s assume I don’t. Any solutions that don’t involve wiring from the basement to the third floor?
- plemansFeb 09, 2022Guru - Experienced User
Powerline might be a decent option. But it can suffer from interference/distance issues so its connection speed decreases.
The r9000 doesn't have repeater/extender mode so you couldn't use that.
You could always get a decent wireless extender that has an ethernet port to connect it to but at that point, you might as well just use the extender and not the R9000.
You're a bit limited because the r9000 needs to be hardwired into something.
- JbienzFeb 09, 2022GuideWell **bleep**. I’m using the R9000 as an AP to try and get better signal on the third floor but it’s taking my gigabit speed down to 30 mbps. Hence the need for a solution.
- JbienzFeb 09, 2022GuideIf I’m able to find the coax, do you know whether I’ll have any issues with my Fios TV if the coax isn’t plugged directly into my FIOS router?
I can't attest to how the coax impacts the fios setup but i've seen many of the fios boxes have moca adapters built in. might be worth checking to as then you'd only need to get 1 for the 3rd floor.
