Jbienz
Feb 09, 2022Guide
Nighthawk r9000 - bridge/Access point
I need some sort of combination of bridge mode and wireless access point and could use some suggestions. I have Verizon Fios and need to keep their router as my main router. That router is located ...
Jbienz
Feb 09, 2022Guide
If I’m able to find the coax, do you know whether I’ll have any issues with my Fios TV if the coax isn’t plugged directly into my FIOS router?
Feb 09, 2022Guru - Experienced User
I can't attest to how the coax impacts the fios setup but i've seen many of the fios boxes have moca adapters built in. might be worth checking to as then you'd only need to get 1 for the 3rd floor.
- JbienzFeb 09, 2022GuideThank you so much. I’m new to this.
Is Hitron a decent brand for the moca adapter?- plemansFeb 10, 2022Guru - Experienced User
I've never needed too use one so I can't attest to how well they work.
My brother has the hiltron moca 2.5 adapters and loves them for his home.
but with any device, check the reviews/specs carefully.
