pasky01
Jan 21, 2022Aspirant
Nighthawk R9000 - Port identification
Is there any way to determine which physical port on the router that a device is connected to? I'm trying to work backward and identify all the physical connections but it's a pain because all my har...
- Jan 21, 2022
You would need to unplug the ethernet cables from the back of the router and look at the LEDs on top to see which port # are which and plug one cable in to each port at a time to see which one is which.
There should be raised numbers or printed numbers in back on the LAN ports.
If not you might take a picture of the ports and print this out and have this on hand to look at.
Jan 21, 2022Guru - Experienced User
