OSUcowboy2685
Sep 18, 2023Follower
Nighthawk R9000 - Slow Wifi
My 2.4GHz and 5.0GHz channels are significantly slower than the gigabit speed flowing into my home via fiber. I can run a speed test on my iPhone 12 Pro while simultaneously connected to the 2.4GHz ...
michaelkenward
Sep 19, 2023Guru - Experienced User
That's how wifi works. It is never as fast as wired. The speed you get depends on the wifi clients you use rather than the router.
It might be worth a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
