OSUcowboy2685
Sep 18, 2023Follower
Nighthawk R9000 - Slow Wifi
My 2.4GHz and 5.0GHz channels are significantly slower than the gigabit speed flowing into my home via fiber. I can run a speed test on my iPhone 12 Pro while simultaneously connected to the 2.4GHz ...
Sep 20, 2023Guru - Experienced User
I'd argue 60-80mbps over 2.4ghz is pretty reasonable. Its a slow network and sensitive to interference. My current home struggles with 2.4ghz because of interference from the surrounding houses. It wasn't until AX that I could get 100+mbps and that's not sustained.
what speeds do you get over 5ghz?
