WGJOC's avatar
WGJOC
Tutor
Apr 23, 2019
Nighthawk R9000, Alexa remote access settings
I've just installed a band-new Nighthawk R9000.  In doing so I thought I'd install the PLEX server and instead of using my Seagate USB drive full of media on my Raspberry Pi I'd plug the Seagate into...
  • schumaku's avatar
    Apr 23, 2019
    Your RasPi was operating on the first LAN behind the provider NAT router - thus  simple port fowarding does the job, probably it did it automatically by UPnP.
    What's the point of adding another router doing NAT again? Your choice ... Check this:
    https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
    Add a DHCP reservation for the R9000 WAN/Internet MAC address (connected to the provider NAT router LAN), then add aport forwarding for port 32400/TCP on the provider router to the R9000 "WAN" IP.
