stoutc24
May 05, 2018Aspirant
Nighthawk r9000 ReadyCLOUD Registration not working
When I go to login to the readyCLOUD portion of the router, I can enter my username and password of myNetgear account (which I know is correct as I have logged into readyCLOUD with the same creds fro...
- May 06, 2018
Downgraded my firmware to 1.0.3.6. rebooted and tried to register. This time all went through. Upgraded to 1.0.3.10 and tried again, broken again. Must be the new **bleep** firmware. Doesn't really surprise me that Netgear has no input on this.
Thanks for your help gentlemen!
michaelkenward
May 06, 2018Guru - Experienced User
stoutc24 wrote:
When I go to login to the readyCLOUD portion of the router, I can enter my username and password of myNetgear account (which I know is correct as I have logged into readyCLOUD with the same creds from 3 different devices)...
I would jump to that conclusion.
I have been confused in the past by the multitude of logins that Netgear throws at us – MyNetgear, readyCLOUD, Parental Controls, Netgear DDNS – and I have been gradually unifying them with the same credentials.
That is probably against all the advice on computer security, but the confusion otherwise is hopeless.
