jmilguy
Feb 13, 2018Tutor
Nighthawk R9000 SFP+ Port
OK.... I have the R9000, and I'm having trouble understanding what this 10 gig SFP+ port is for. I have 2 TP-Link switches with SFP ports, and use them with fiber interconnects, so I'm no stranger t...
- Apr 21, 2018
I'm pretty sure that, while this router is relatively powerful for what it DOES DO, I'm about to just sell the thing at a loss, and purchase one of the pro models from Ubiquity....
jmilguy
Feb 14, 2018Tutor
Case850..... I don’t want to use it as a WAN port, but just get internet out of it, as I can with the LAN ports. Again, it seems that this thing is becoming more and more, an expensive paper weight.... I appreciate your thoughts!
kaiatkins
May 14, 2018Guide
With the newest firmware you can now use the sfp+ port for WAN then you have 7 LAN ports ethernet :)
- MikeofmlJun 01, 2018Guide
This is great, so I do not need any media converter anymore? Just to plug the WAN into the SFP port. Great as I have a 10 GB WAN.
Thanks for quick answer. I have a
HUA-SFP-10G-BX-U-LR20-O
Huawei SFP+10GBASE-LR SFP+,BiDi,Tx1270nm/Rx1330nm,20km
module in my media converter right now. Do you know if this will work?
My plan was to skip the media converter (Planet IXT-705AT) that converts my 10GB fiber signal into a copper RJ-45 signal and plug the SFP module directly into my R9000.
So to answer your question it will be a remote box at the station but the SFP module works today together with the planet media converter. I just wanted to get 10GB WAN fiber directly into my R9000.
Yes you understod the setup correctly.
thanks for your support, I will try bypassing the converter this weekend.
- schumakuJun 01, 2018Guru - Experienced User
Mikeofml wrote:
HUA-SFP-10G-BX-U-LR20-O Huawei SFP+ 10GBASE-LR SFP+,BiDi,Tx1270nm/Rx1330nm,20km module in my media converter right now. Do you know if this will work?
Netgear does not enforce any specific vendor ID or models on the R9000. Same applies ot the Smart Managed Plus and Smart Managed Pro switches btw, too. Go for it and try!
For the curious - where are you located, what ISP, ...? Would be great to collect some reference data. Awaiting Salt Fiber (XGS-PON) installation these days here in Switzerland (delayed as we had to insist we wanted to keep the other FTTH connections).
- MikeofmlJun 02, 2018Guide
I am located in Sweden and have Bahnhof as ISP.
- kaiatkinsJun 04, 2018Guide
I am located in Cambodia using SInet.
- MikeofmlJun 06, 2018Guide
It worked fine with the 10GB port. Now I have 10GB fiber directly into the router. Downloaded 3
x1GB at the same time with different computers to test. Worked just fine.
I am running in router mode.
- MikeofmlJun 15, 2018Guide
