toddvohs
Jun 07, 2021Aspirant
Nighthawk R9000 X10 AD7200 DHCP Internet Interface
I have had this R9000 since it was released and it is surprisingly fast. We recently moved and I updated our internet service, same provider just went from 100 to 400 mbps service. Still works grea...
Jun 08, 2021Guru - Experienced User
I'd buy a cheap backup power supply and put both the modem and the router on it.
Might be the easiest fix for you.
If it worked fine before and the only change was spectrum's device, that could be the issue. :)
What actual modem is it from spectrum.
