Nick7772011
Sep 18, 2021Aspirant
NightHawk R9000 X10 Wireless Keeps turning off
Hey everyone, I have a the R9000, and just recently since the latest firmware update have been have an issue, the wireless turns off and I cannot turn it back on unless i reset router to defaults the...
Sep 19, 2021Guru - Experienced User
Have you tried simply downgrading back a version?
Maybe the update broke something.
Nick7772011
Sep 19, 2021Aspirant
Thanks for the replay, sorry forgot to put that in my original post. I did downgrade and had the same issue, then upgraded and put it back to new firmware.
- plemansSep 19, 2021Guru - Experienced User
How old is it?
when you reset, if you leave it with the default settings, does it still shut down?
- Nick7772011Sep 19, 2021Aspirant1 year 8 months old. Yes does the same thing. I just did it again last night and it is good for now, but sometimes it happens days later or hours later.
I'm just curious if the defaults cause it as well (even leave the ssid as the defaults)
