Nick7772011
Sep 18, 2021Aspirant
NightHawk R9000 X10 Wireless Keeps turning off
Hey everyone, I have a the R9000, and just recently since the latest firmware update have been have an issue, the wireless turns off and I cannot turn it back on unless i reset router to defaults the...
Sep 19, 2021Guru - Experienced User
How old is it?
when you reset, if you leave it with the default settings, does it still shut down?
Nick7772011
Sep 19, 2021Aspirant
1 year 8 months old. Yes does the same thing. I just did it again last night and it is good for now, but sometimes it happens days later or hours later.
- plemansSep 19, 2021Guru - Experienced User
I'm just curious if the defaults cause it as well (even leave the ssid as the defaults)
- Nick7772011Sep 19, 2021AspirantYes i tried defaults and it did the same thing after a couple of hours.
when the wifi dies, is it hot?
maybe its over heating and thats causing the wifi to shut down
