voltagejim
Sep 01, 2021Tutor
Nighthawk RAX80 and SIP VOIP issues
Got a nighthawk router and comcast internet. We went to a new phone system at work which is based on SIP. We all use the same exact phone at work which is a Yealink SIP-T46S, and phones work perfec...
Sep 01, 2021Guru - Experienced User
You can try setting the phone with a reserved IP address. After that, setup the phones IP address in the DMZ.
- voltagejimSep 01, 2021Tutor
cool, will try that this evening
SO I got home with the phone and plugged it into the router and it actually worked for like 30 minutes before suddenyl giving me a "No service" message. I tried setting the default DMZ server to the IP that the router gave to the phone, but made no difference.
