voltagejim
Sep 01, 2021Tutor
Nighthawk RAX80 and SIP VOIP issues
Got a nighthawk router and comcast internet. We went to a new phone system at work which is based on SIP. We all use the same exact phone at work which is a Yealink SIP-T46S, and phones work perfec...
Sep 02, 2021Guru - Experienced User
what modem are you using?
voltagejim
Sep 02, 2021Tutor
Using a Motorola surfboard SB 6141
- plemansSep 02, 2021Guru - Experienced User
Are you using IPv4 or IPv6?
I don't know a whole lot about that phone but it looks like its has its own dhcp server built in that can be used/disabled/changed.
Might be worth checking with Yealink on what setting is best for home use with its dhcp server setup.
- voltagejimSep 02, 2021Tutor
using ipv4 at home.
I know we use the FreePBX system at work and we have it setup for DHCP where the phone gets an IP from ur DHCP server at work.
