voltagejim
Sep 01, 2021Tutor
Nighthawk RAX80 and SIP VOIP issues
Got a nighthawk router and comcast internet. We went to a new phone system at work which is based on SIP. We all use the same exact phone at work which is a Yealink SIP-T46S, and phones work perfec...
voltagejim
Sep 02, 2021Tutor
Using a Motorola surfboard SB 6141
Sep 02, 2021Guru - Experienced User
Are you using IPv4 or IPv6?
- plemansSep 02, 2021Guru - Experienced User
I don't know a whole lot about that phone but it looks like its has its own dhcp server built in that can be used/disabled/changed.
Might be worth checking with Yealink on what setting is best for home use with its dhcp server setup.
- voltagejimSep 02, 2021Tutor
using ipv4 at home.
I know we use the FreePBX system at work and we have it setup for DHCP where the phone gets an IP from ur DHCP server at work.
Have you tried it with IPv6?
Also, your work dhcp server might be setup different than a home setup. Might be worth checking with Yealink on it for what their recommendations are for their phone. Especially since its the only thing having issues.
