RobotBadGuy
Aug 06, 2021Aspirant
Nighthawk RAX80 No ethernet cable is plugged into the router internet port
Hi I purchased a Nighthawk RAX80 router and when trying to connect to internet im getting an error - 'no ethernet cable is plugged into the router internet port'. I've tried resetting & power cyc...
- Aug 08, 2021
RobotBadGuy wrote:
In your experience would this suggest a network reboot as you mentioned?
There is no harm in doing that. For some strange reason, some people think that Netgear is misguided when it tells people how to set up a router and the correct order for doing things.
RobotBadGuy wrote:
Sorry I forgot to reply to one of your questions. I am seeing this error when going through the wizard on the netgear app & also through the browser. So it basically goes through the motions and then at the end says no cables attached.
Those dratted wizards are sent to baffle us all. Have you tried the section in the manual for the RAX80 Manually Set Up the Internet Connection.
That would let you provide the login details for your Internet service which should deal with this bit:
RobotBadGuy wrote:
So if I plug my router into the modem with ethernet, the internet/ethernet icon on the router does not light up.
From what I have read here, there is something about NBN ISPs. They seem to like making their own "tweaks" to the settings. There are so many ISPs playing around that it can be hard to work out what to do. This can frustrate Netear's automated setup processes.
There have been so many questions here about NBN that your ISP's name may have come up in the past. You could try plugging your ISP's name into the Netgear community.
Here's a good place to start looking for local expertise:
It seems to be frequented by knowledgeable people and is hopefully free of the condescending types who turn up here with the specific aim of belittling everyone else. Apologies for that.
RobotBadGuy
Aug 07, 2021Aspirant
Hi Michael,
In summation it appears that the router can't connect directly to the modem (through direct wired connection) So if I plug my router into the modem with ethernet, the internet/ethernet icon on the router does not light up.
- The router ethernet port is working and I can use it as a range extender. (ethernet/internet icon lights up on router when connected to my old router)
antinode
Aug 07, 2021Guru
> [...] I'm connecting to a NBN fibre modem [...]
Not a very detailed description. Maker? Model number?
> [...] Definitely not my ethernet cable as I'm still able to connect
> using my previous netgear router
Not a very detailed description of that device, or how it's
configured.
> [...] I've read it could be a faulty ethernet port - if this were the
> case is it repairable?
Sure, the port could be bad, but that's not the only possible cause
of a dark "Internet" indicator. A LAN Ethernet port-status LED lights
when there's a good physical link; the "Internet" LED needs more. Any
WAN misconfiguration (bad PPPoE credentials, bad VLAN parameters, ...)
could keep the "Internet" LED dark. Repair is typically impractical,
but actual hardware problems are rare.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions.
Note that "NBN" means little more than "Australia", and, by itself,
provides no actual information about how a router should be configured.
Your (unspecified) actual ISP might provide more details. As might
inspection of your (unspecified) "my previous netgear router", which, I
hear, works as expected.
> [...] 'no ethernet cable is plugged into the router internet port'
I've never touched an RAX80, so I know nothing, and Netgear router
firmware is seldom defect-free, but I'd expect that message to mean what
it says. If, however, it's just shadowing the "Internet" LED, then it
could be just as easily misinterpreted.
One more realistic test would be to put the (unspecified) "my
previous netgear router" back into place, configure the RAX80 as a
wireless access point ("Set up the router as a WiFi access point" in the
RAX80 User Manual), and see if _that_ works. If so, then move the
(unspecified) "my previous netgear router" close to the (unspecified) "a
NBN fibre modem", and use the long cable to connect the (unspecified)
"my previous netgear router" LAN port to the RAX80-as-WAP WAN/Internet
port. If _that_ works, then I'd conclude that the RAX80 WAN/Internet
port and the long cable are both ok.
> Remember, when replacing one device in a network you have to go
> through things on the right order.
This is largely baseless folklore. Especially inapplicable when the
router is connected to an ONT which has negligible start delay. If that
sort of care were actually required to start these gizmos, then I'd
expect there to be a large market for home-network power sequencers.
Ever seen one?
But, if you have time to kill, ...
- RobotBadGuyAug 07, 2021Aspirant
Hi antinode thanks for your reply.
my (unspecified) "a NBN fibre modem" is unknown - its a NBN provided connection box and power supply - acts as the modem
my (unspecified) "my previous netgear router" - is a Netgear R6300 wifi router
The setup is basically this - NBN connection box is in the garage, wire from NBN box to Ethernet Point 'A' on the wall. Ethernet point 'A' is wired to another Ethernet Point 'B' inside my house. I connect my R6300 to Ethernet Point 'B'.
Yes I've done that test that you mentioned - which leads me to believe that the ports & cables are working. So right now my R6300 is wired to the modem (ethernet point B) & the RAX80 router is connected to the R6300 using a long wire. I can wirelessly connect to the RAX80 successfully (or hardwire connection from my pc to the RAX80)
So it seems to fall over when I directly connect my RAX80 to the modem - it doesnt detect the ethernet for some reason? The LAN Ethernet port light on my RAX80 does NOT light up at all.
- antinodeAug 07, 2021Guru
> [...] its a NBN provided connection box and power supply [...]
> [...] Maker? Model number?
Still a mystery. I'm willing to pretend that it's a harmless ONT,
but knowing what it actually is would inspire more confidence.> [...] is a Netgear R6300 wifi router
R6300[v1] or R6300v2? Look for "Model" on the product label.
With my weak psychic powers, I still can't see how its Internet stuff
(BASIC > Internet) is configured, or how the same stuff is configured on
the RAX80.
> [...] wire from NBN box to Ethernet Point 'A' on the wall. [...]I'm lost already. What, exactly, does "Ethernet Point 'A' on the
wall" mean to you? What, exactly, is connected to what, exactly?
> [...] it doesnt detect the ethernet for some reason? [...]"Ethernet" and "Internet" are spelled differently for a reason.
> [...] The LAN Ethernet port light on my RAX80 does NOT light up at
> all.Assuming that you actually mean "Internet", not "LAN", that's not
news.
Did you consider trying this radical concept (which works for some
people)?:https://en.wikipedia.org/wiki/RTFM
"Reset".
I'd try taking some arrangement where the R6300[vX] is working, and
move the cable from its WAN/Internet port to the WAN/Internet port on a
freshly reset RAX80, and go through its normal set-up wizard stuff, as
described in the RAX80 User Manual.- RobotBadGuyAug 07, 2021Aspirant
Thanks node, I appreciate the assistance (even though its infused with a bit of condescension lol) unfortunately the people who are seeking help usually wont be as experienced as yourself in this area - hence why we seek support.
if you read through some of my reply you would see I've done a reset already, several times. I've gone through the wizard and power cycles several times. (as described in the RAX80 user manual)
In short - the Internet LED light on the RAX80 is OFF even when the ethernet cable is connected between the RAX80 and the modem.
anyway all good, I'll go through it all again and hopefully it works
