McDoogie
Aug 12, 2015Tutor
Nighthawk Remote Access With AT&T Arris NVG589 Modem
Hello, I am trying to use the Remote Access feature on my Nighthawk Router. Currently with Remote Access enabled I get these two IP addresses from the nighthawk: 192.168.1.X: port number and 2602:...
McDoogie
Aug 12, 2015Tutor
Thank you for the reply! What exactly would i need to port forward in the modem?
JamesGL
Aug 12, 2015NETGEAR Employee Retired
The port number that remote access is using. Check if the modem has port forwarding feature. Once port forwarding has been done, you can access it via the WAN IP:Port number.
JamesGL
Community Team
