McDoogie
Aug 12, 2015Tutor
Nighthawk Remote Access With AT&T Arris NVG589 Modem
Hello, I am trying to use the Remote Access feature on my Nighthawk Router. Currently with Remote Access enabled I get these two IP addresses from the nighthawk: 192.168.1.X: port number and 2602:...
TheEther
Aug 12, 2015Guru
192.168.1.200: port number
and 2602:xxx:xxxx:xxx::xx]: port number
The 192.168.1.200 is the static IP given to my Router from my Modem. The second IP address is the one that should be the remote access, but when I try it, it simply does not work, and it just does not look correct.
Any help on this would be appreciated. IF anyone needs any more information about anything just ask!
Thank you!
That second IP address is actually an IPv6 address.
I would think twice about enabling remote access on your Nighthawk. It will make it easier for hackers to break into your network.
If you are still determined to do this, then instead of setting up a port forward on the modem, you might be better off enabling IP Passthrough on the NVG589. This is a pseudo-bridge mode for the modem. The important point is that your Nighthawk's WAN interface will receive the same public IP address as your modem. Then you should be able to remotely access your Nighthawk using the public IP address.
dslreports.com has a good article on setting up IP Passthrough. https://www.dslreports.com/faq/17734
