McDoogie
Aug 12, 2015Tutor
Nighthawk Remote Access With AT&T Arris NVG589 Modem
Hello, I am trying to use the Remote Access feature on my Nighthawk Router. Currently with Remote Access enabled I get these two IP addresses from the nighthawk: 192.168.1.X: port number and 2602:...
McDoogie
Aug 13, 2015Tutor
Because the remote access didn't work.I was able to get this to work at a client's house with the same router but they had a time Warner cable modem. the modem was in bridge mode, and I enabled remote management on the nighthawk router, and it work, I was done in like 5 minutes. But it seems uverse is much different since they dont have a bridge mode. I don't know If my modem settings are correct or what. I'll check in the packet filters when I get home
