McDoogie
Aug 12, 2015Tutor
Nighthawk Remote Access With AT&T Arris NVG589 Modem
Hello, I am trying to use the Remote Access feature on my Nighthawk Router. Currently with Remote Access enabled I get these two IP addresses from the nighthawk: 192.168.1.X: port number and 2602:...
McDoogie
Aug 13, 2015Tutor
Update: I just tried the 75.X.X.X ip at my girlfriend's house, even though before I left I reset my router to 192.168.1.200. And it's working. Not sure I understand why. I have the 192.168.1.200 ported in my modem currently. But it's working. Can anyone exlpain?
TheEther
Aug 13, 2015Guru
Perhaps you didn't apply the change back to 192.168.1.200? Anyway, it's a little unfortunate that you published your real IP address. Anybody can now try to brute force their way into your router. You better have a really strong password.
