McDoogie
Aug 12, 2015Tutor
Nighthawk Remote Access With AT&T Arris NVG589 Modem
Hello, I am trying to use the Remote Access feature on my Nighthawk Router. Currently with Remote Access enabled I get these two IP addresses from the nighthawk: 192.168.1.X: port number and 2602:...
McDoogie
Aug 13, 2015Tutor
Update: I just tried the 75.X.X.X ip at my girlfriend's house, even though before I left I reset my router to 192.168.1.200. And it's working. Not sure I understand why. I have the 192.168.1.200 ported in my modem currently. But it's working. Can anyone exlpain?
JamesGL
Aug 17, 2015NETGEAR Employee Retired
Hi McDoogie,
Did you set port forwarding on the modem using the port number used for Remote management? The reason it works might be becuase of the modem forwarded the request to the router.
JamesGL
Community Team
- TheEtherAug 17, 2015Guru
If McDoogie is still using IP Passthrough, then port forwarding isn't required.
