McDoogie
Aug 12, 2015Tutor
Nighthawk Remote Access With AT&T Arris NVG589 Modem
Hello, I am trying to use the Remote Access feature on my Nighthawk Router. Currently with Remote Access enabled I get these two IP addresses from the nighthawk: 192.168.1.X: port number and 2602:...
JamesGL
Aug 17, 2015NETGEAR Employee Retired
Hi McDoogie,
Did you set port forwarding on the modem using the port number used for Remote management? The reason it works might be becuase of the modem forwarded the request to the router.
JamesGL
Community Team
TheEther
Aug 17, 2015Guru
If McDoogie is still using IP Passthrough, then port forwarding isn't required.
