McDoogie
Aug 12, 2015Tutor
Nighthawk Remote Access With AT&T Arris NVG589 Modem
Hello, I am trying to use the Remote Access feature on my Nighthawk Router. Currently with Remote Access enabled I get these two IP addresses from the nighthawk: 192.168.1.X: port number and 2602:...
TheEther
Aug 17, 2015Guru
While you may have gotten remote access to your router working, this is most likely a suboptimal setup overall because both your router and your modem are performing NAT. Read this article on why double NAT is bad idea. IP Passthrough avoids double NAT.
Anyway, if everything is working...
McDoogie
Sep 01, 2015Tutor
now that i got it figured out, anyway to delete this thread?
