chopin70
May 28, 2016Virtuoso
Nighthawk rooters and https admin GUI
Hi, Why we still don't have any option to access GUI management through https and disable http, either for remote management and for local management Using http any being impossible to disabl...
- May 29, 2016
Sorry, I meant page 160. The example shows: http://134.177.0.123:8080 when it should be https://137.170.0.123:8080.
On page 159, the picture shows Remote Management Address: https://0.0.0.0:8443.
chopin70
May 29, 2016Virtuoso
I never tried remote, but through LAN. Only option is http
In manuals and options, i only see http for remote, with option to change port, which is kidding as of security
Even locally, a bad site can sniff the pass by redirecting a simple malicious script to the http admin gui. If you saved pass, it can sniff it
- TheEtherMay 29, 2016Guru
Remote management is definitely https, not http. The R7000 manual has a typo on page 180. If you look on the configuration screen on page 179, it's correctly shown as https.
The local connection is still http, so you still have a valid point, here. You can vote for adding https here.
- chopin70May 29, 2016Virtuoso
I see nothing relevant P180 !
Remote management is in P159-160
It definately shows using http through a custom port, no SSL through 443 port
